NEED HELP WITH FLIP UP HEADLIGHTS
Old Jan 10, 2008 | 03:09 PM
redformula88's Avatar
I took my car to a shop for a completely new setup(motor,trans,rear,etc.)they also were going to rewire the whole car and they did.but now they can only get the headlights to go up or down but not both(up and down)Does anyone know where i can get a wiring diagram of the headlights and maybe that can solve the problem? any help is greatly appreciated.the car ia an 88 Formula
Old Jan 10, 2008 | 06:09 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Re: NEED HELP WITH FLIP UP HEADLIGHTS
Here's what I've got out of the '88 factory service manual. If wiring is correct, problem may lie in lighting module on firewall.
Good Luck,
Corky
Attached Thumbnails NEED HELP WITH FLIP UP HEADLIGHTS-light_switch.jpg   NEED HELP WITH FLIP UP HEADLIGHTS-headlight-door.jpg
Old Jan 10, 2008 | 07:17 PM
where exactly is the lighting module located?the reason i ask is that the car was converted to a carb and a lot of the factory stuff is not there anymore.thanks
Old Jan 10, 2008 | 07:40 PM
Corky's Avatar
Engine: 2.8L
Standing in front of car. Headlamp module is to the left of master cylinder mounted on the firewall. 4.5" square black box with 2 wire connecters plugged into it - has the word GUIDE embossed on it.
Corky
Old Jan 11, 2008 | 12:54 AM
ok yea i remember taking that off the car and i know its not on there right now so what exactly does that do?
Old Jan 11, 2008 | 02:59 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It turns on the headlight motors and shuts them off once is senses the spike in current from the headlight bucket hitting it's physical stop. If it doesn't sense the spike in current (due to bad bushings inside the gear within the motor) it will turn the motors off after 6 seconds. If you're wiring it back to original you'll need the module from a 1987-89. The one for a 1990+ is different because the wiring changed.
Lon
Lon
Old Jan 11, 2008 | 02:59 PM
im guessing that may be the problem because i know that piece is not currently on the car. hopefully that will solve the issue.thanks for your help guys
Old Jan 11, 2008 | 06:52 PM
Corky's Avatar
Engine: 2.8L
Most cars I've seen at the boneyard still have the module intact. If you don't have the module, that might be your best and cheapest option.
Corky
Old Jan 13, 2008 | 08:47 AM
thfirewithin's Avatar
Car: 1990 Pontiac Firebird
Engine: v6 3.1L
Transmission: Automatic
Axle/Gears: ???
it could be the arm that moves the light. i have a problem with mine also. Only 1 headlight goes up and comes back down. When i took a look at it, the arm on the one that isnt working, is overextended. check and see if that could be it.
Old Mar 22, 2008 | 05:06 AM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
how do you check that, i know its not the motor, so any other suggestions
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
