TRICKY SPEEDOMETER PROBLEM CAUSING BLOOD IN STOOL
Old Jan 13, 2008 | 07:27 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
IVE DONE EVERYTHING TO GET THIS SPEEDOMETER TO WORK EVEN JUST SWITCH ONCE FOR ME BUT I GET NOTHING. IVE CHANGED THE VSS, 4 WAY BUFFER BOX, GAUGES (3 TIMES). SOMEONE TOLD ME IT MIGHT HAVE SOMETHING TO DO WITH THE CRUISE CONTROL THAT I REMOVED. ANYONES THOUGHTS ARE VERY APPRECIATED. IM TRYING TO SELL THIS CAR AND CANT CAUSE OF THIS PROBLEM. I ALSO HAVE CARBED THIS CAR AND REMOVED THE COMPUTER.
Old Jan 14, 2008 | 05:13 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: TRICKY SPEEDOMETER PROBLEM CAUSING BLOOD IN STOOL
What kind of trans is it and what year? is it a cable speedo or an electric?
There is a VSS signal that goes to the cruise control but it wouldn't effect the speedo by removing it.
Old Jan 14, 2008 | 07:48 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
it might be the speedo gear if mechanical that is stripped and if its electronic might be worn out to read.
Old Jan 14, 2008 | 07:47 PM
Axle/Gears: YEP
okay its an electrica speedometer manual trans (t-5)
Old Jan 15, 2008 | 01:17 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
is it the stock gauges? Did you change anything before it stopped working? Are the grounds good?
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
toones
Jan 6, 2016 06:00 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
AUZ28
Oct 12, 2015 08:40 AM
