Fuel Gauge
Fuel Gauge
ok well i am converting my Tpi car to a carb and i took all the computer and engine wiring out and all the original gauges cuz im going to be using after market gauges what should i do about a fuel guage? what kind do i need, whats the ohm stuff all about and can i use my stock fuel sender in the tank or what?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Fuel Gauge
I have never swaped a Fuel injected motor over to a carb set-up without removing the tank so the gas pick-up could be replaced with a Carb type pick-up.
I've been told you can simply remove the pump from the fuel injected pick-up and re-use it,... but have never tried it.
As far as the gauge,.....
in the Engine swap forum.
Ghettobird52
Jul 5, 2024 11:18 PM
R3500
Aug 17, 2015 12:16 PM
