help me lay this out...
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
The Body harness from the drivers side of the car:
Alternator and Starter wires
Coil 12v and tach plug in
Oil pressure switch
12v to electric choke
What are all the other wires on this harness? They just hang there.
update:
I know some go to my wiper motor and washer pump which are these?
Oil pressure switch
update:
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: help me lay this out...
Depending on what year the harness was originally from
1 plug for the ECM harness connection
1 plug for the Fan relay
2 plugs for the heater system ( 1 Red wire plug - the other will have Black, Blue, Green )
1 plug for AC compressor ( Green & Brown wires )
1 plug for temp sending unit ( Green )
1 wire for throttle kicker ( Blue )
2 plugs for wiper motor
1 plug for ESC system
I Hope that helps !
Edit:
These will come out of the harness right next to the oil pressure wire. Yellow and Purple wire plug to the motor and the other plug depends on the year of the harness, ( Green, Grey, Yellow, and Pink for an 86 )
I Hope that helps !
Edit:
Last edited by John in RI; Jan 15, 2008 at 11:38 AM. Reason: reply to edit in orig post
UltRoadWarrior9
Apr 28, 2020 10:39 PM
gta892000
Sep 16, 2015 12:37 AM
