removed my ECM...
Old Jan 14, 2008 | 09:40 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
removed my ECM...
I know the plugs that go directly into the ECM are from the engine sensors.
Where do the plugs that meander off to the right under the dash off the ECM control go or do?
Basically, there's two that go to the ECM itself, But what do the other two do?
Old Jan 15, 2008 | 11:42 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: removed my ECM...
TCC Lock-up for Automatics,...... Some Manual tranny cars have the reverse light wires running through that connector. Again - it depends on what year and engine/tranny type the dash harness is from.
Sounds like you need to get yourself a shop manual !!!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
