So Gauges, and wipers dont work, why?
Old Jan 24, 2008 | 07:05 PM
Firebird_dave7's Avatar
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
Why is this happening, i have swaped my LG4 for a 350 carb'd and only my lights work but my turn signals barely work! i have taken alot of my ecm wiring out.
So where can i look and everything?
Old Jan 24, 2008 | 07:34 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: So Gauges, and wipers dont work, why?
check the fues. maybe you have a bad ground or you didnt hook up a ground wire.
Old Jan 25, 2008 | 04:50 AM
Car: 1987 Firebird
Well i already checked my Fuse Block and a few grounds but i will check again, and again. but could there be something else.
Old Jan 25, 2008 | 11:10 AM
406maro's Avatar
Car: 1986 Camaro Berlinetta
Engine: 406 roller
Transmission: th 350
Axle/Gears: 4.10
Dont know if it could be the same thing but i had alot of electrical issues because of a bad gauge cluster. Switched them out and it fixed most of the problems. Just a thought.
Old Jan 25, 2008 | 02:58 PM
Car: 1987 Firebird
My gauges worked great before i did the swap.
Old Jan 26, 2008 | 10:17 AM
Car: 1987 Firebird
Well i got the turn signals and wipers working.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Jk_Under
Aug 17, 2015 03:08 PM
slade5612
Aug 11, 2015 07:19 PM
