what is that little black box for?
Old Jan 25, 2008 | 05:03 PM
jeff lucas's Avatar
Car: 92 camaro rs
Engine: 383 stroker (518 hp)
under the center console right next to the e-brake there is a little black box with i believe it was 6 wires going in to it with a ground to the body. i have completely gutted the inside to cut weight and i was curious if this was a vital piece of equipment. i would have traced it out but it started to pour down rain. thanks, jeff
Old Jan 25, 2008 | 05:09 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: what is that little black box for?
I believe it's the relay for the hatch release.
Old Jan 25, 2008 | 05:16 PM
jeff lucas's Avatar
Car: 92 camaro rs
i guess i'll have to trace it out tomorrow to find out for sure seeing that wasn't a definite answer, thanks for the reply
Old Jan 26, 2008 | 12:04 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you have airbags, there will be another box (sensor) in there. The only way to tell for sure is to check the wire colors.
Lou
Old Jan 26, 2008 | 04:23 PM
84camaro84's Avatar
Engine: 5.0 H.O.
Transmission: 5-Speed
I don't know if your talking about the same thing I was curious about. I just stripped my interior as well on my 84, right now next the the e-brake i have 2 harnesses for the power windows, 1 harness for the hatch, and 1 black box/plug that a bunch of wires run into. I assumed that it was a harness but not plugged into anything and was meant for the optional analog clock that was available between the console and power window switches. (If we are talking about the same black box) But I'm just gonna leave mine in because too many wires run through it.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
MantyZ28
Jan 18, 2016 08:30 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
zayne0
Aug 24, 2015 07:22 PM
