starter removel trouble
Old Jan 29, 2008 | 03:30 PM
85 camero's Avatar
Car: 85 berlinetta
Engine: 305 lg4 q-jet
Axle/Gears: stock going 3.73 posi
first starter wire was bad,then cylonoid went out,know the starter doesnt want to come out.i have a replacement starter but cant get old one out,how does the starters come out,do i have to drop the y-pipe?y-pipe and frame is in way in one spot and tranny lines are in way in another so whats the esiest way to get starter out?thanks
Old Jan 29, 2008 | 05:57 PM
Re: starter removel trouble
Piece of cake; they come right out.
Nose down. IIRC with the solenoid toward the front of the motor. Be careful it doesn't fall on your hand or anything, it might surprise you.
Old Jan 29, 2008 | 06:28 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I have a manutal transmission so I wouldn't know about the tranny cooling lines but once you remove the 2 starter bolts (and all wires), you can slide the starte a little bit fwd and it drops down easily.
Lou
Old Jan 29, 2008 | 09:10 PM
kcb37's Avatar
You may have to lift, push forward, turn, drop and end. Something like that in any order.
I have never had to do anything to get a starter out other then play with the starter.
I did sell my Sonoma to a friend who said he had to lift the engine and take the exhaust manifolds out to get the starter out.
All I have to say is he knew it was going before he bought it.
Old Jan 29, 2008 | 09:37 PM
85 camero's Avatar
Car: 85 berlinetta
ill see how it goes tomorrow.was fighting with 40 mile an hour winds and rain today so that didnt help matters any,ive just never had this much trouble gettin a starter out of any vehicle before.thanks for the help and ill let yens know how it goes.
Old Jan 29, 2008 | 10:53 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Just try to remember, when the starter drops down, stop and take a real good look at how its oriented, because thats the only way its going back in.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
mrbird
Oct 20, 2015 03:43 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Lmancha96
Sep 25, 2015 08:11 PM
