What in the world just happened???
Old Feb 13, 2008 | 11:14 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
when i left for work the power was completely killed to my car. No interior lights or anything. then i jump start it. It turns on but when i put my auxillary on my battery, it gets killed. Then i get it jump started again, but the battery wouldnt go on. My light for the door wasnt on is how i knew. Then all of sudden i smack the battery and it goes on. I start the car then get ready to back out, i turn my lights on and it gets killed again. but this time i could start it by myself.
At my house i do every check in the world to see if i get a drain at all. ANd nothing. all i found was my knock sensor wire rubbing a header. But it wasnt enough to lose charge like that. All i could think was that knock sensor was shutting the car down or sumtin. idk
Also I had my car scanned today by my friend. Any correlation????
Old Feb 14, 2008 | 07:46 AM
uemf's Avatar
Car: '86 Firebird
Engine: '85 TPI on crate 350
Transmission: T-5 man
Re: What in the world just happened???
to me it sounds like a bad battery cable or ground ... to start with
When my battery cable started going bad, all of my lights would work until I hit my starter. Then everything would go out for a while (minutes).
What do you mean by putting your auxillary on ?? putting the key in aux position?
I guess the battery could be internally damaged... get it tested.
Old Feb 14, 2008 | 09:25 AM
jvontungeln's Avatar
Car: 83 Camaro
Axle/Gears: 342's
You also could have an internal short in the battery. I have seen cases of side post batteries losing conection to the plates.
Clean the connectors and do some testing.
1. Check the voltage across the battery terminals, is it fully chargerd? Should be ~ 12.6V
2. Check the same voltage while a friend attempts to crank the engine. Looking for a significant voltage drop to ID a bad battery.
3. Check the voltage of the battery cable connection to the starter (keeping the negative on the battery ground). This will test the voltage drop throuth the cable. Once again a significant drop at this point shows a connection problem, cable or corosion.
bob8703's Avatar
sounds like there is a loose connection somewhere. for it to start working after hitting it. check the connectors make sure they are tight. and check the cables make sure there are no breaks in the wires. and that the grounds are ok.
Old Feb 14, 2008 | 11:59 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
... brad you describe things so poorly... his AUX is that he has a dual post battery with the side terminals set up for the stock use and top terminal is for his stereo...
Brad have you ever double checked any of the connections to make sure they arent loose....
also if you keep buying the cheapest autozone battery is possible for this to happen
although this is battery # wat 6 in 3 months.....
btw when are you gunna gimme back my TPI set up...
Last edited by Saigon_Bob; Feb 14, 2008 at 12:00 PM. Reason: Automerged Doublepost
Old Feb 15, 2008 | 01:54 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Look i more than double checked it alex. I dont get it it at all. I belive my ignition switch is bad actually. I start my car fine with the push button but not with the key itself. Come get it when you time my car.
Old Feb 15, 2008 | 08:22 AM
bob8703's Avatar
^^^^ i sense a disturbance in the force. ^^^^
InfernalVortex
Apr 20, 2021 11:31 AM
RS Reaper
Oct 17, 2018 07:52 PM
gt4373
Oct 8, 2015 10:37 AM
racereese
Oct 3, 2015 03:46 PM
Damon
Sep 26, 2015 04:29 PM
