Turn Signal stays solid - Flasher?
Old Feb 15, 2008 | 02:13 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
I have a 1992 camaro and the turn signal stays solid when I put it on for both ways. I have no lights out and the hazard lights work. When I located the flasher for the hazard lights I figured the turn signal would be right underneath of it the white one with 3 prongs so I replaced it and it still does not work. I need this problem fixed and I don't know what else it could be.
Old Feb 15, 2008 | 02:23 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Re: Turn Signal stays solid - Flasher?
Turn on your hazards and, by sound and touching the flasher, locate the one for the hazards. This will insure that you replaced the turn signal flasher.
Old Feb 15, 2008 | 02:35 PM
robster66's Avatar
Engine: 305 T.B.I.
I did I already took out the hazards one and it stopped blinking and the one below it I figured was the turn signal so I replaced that and it still does not work
Old Feb 15, 2008 | 02:47 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
i've had this issue for awhile now (close to a year) good luck on finding a solution... make sure you have all working bulbs in the car (trunk, side markers etc) ....i hvae that left to do, right now im seeing and pretty much believing it has something to do with my turn signal switch inside the column
Old Feb 15, 2008 | 03:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A burned out bulb is the first thing to check when it's not flashing.
Old Feb 15, 2008 | 03:26 PM
robster66's Avatar
Engine: 305 T.B.I.
All the bulbs are fine like I said =/
Old Feb 15, 2008 | 04:27 PM
jvontungeln's Avatar
Car: 83 Camaro
Axle/Gears: 342's
Look for a bad ground at the bulb end.
Old Feb 15, 2008 | 04:30 PM
robster66's Avatar
Engine: 305 T.B.I.
Is the stock flasher in a 92 camaro the white 3 pronged one?
Old Feb 15, 2008 | 04:47 PM
robster66's Avatar
Engine: 305 T.B.I.
Alright now I am just convinced I am an idiot and shouldn't be doing this kind of work. I think what I replaced was the horn relay which is directly underneath the hazard light flasher and I think I found the turn signal flasher which is mounted on the side of the fuse box.
Old Apr 9, 2008 | 01:15 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
I have a similar problem.
ALL my bulbs function properly, all turn signals flash etc, but ONE of them will stay OFF when the headlights are on, yet it still flashes when I signal without a problem....
I can only assume it must be the "switch" wire for the running lights that is not turning it on....grrrr
anyone know which wire that is so I can test it?
Old Apr 10, 2008 | 12:21 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
even if the bulbs are good.. some times the connector/connections need cleaned. it helps
Old Apr 10, 2008 | 02:50 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
The flasher is a thermo sensitive device and requires current to function correctly, a bad contact, bad ground or burnt out bulb will reduce current in this circuit. A slow blick usually is a bad bulb, no blink or constant light is usually a bad connection or bad ground....a fast or rapid blink usually means over current some where, maybe a short or cross wires.. typical with tow bar wiring.
Old Apr 10, 2008 | 12:28 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Thanks.
Mine is confusing though because it will blink perfectly normally, it just won't some on as a running light at all (but still blinks fine when the other running light is on)
...I tried to twist the bulbs out the other day and they won't move.
I assume they are just "normal" bulbs you twist and pull to get out?
(so I should just pull harder?....could be a sign or corrosion itself...)
Old Apr 10, 2008 | 01:09 PM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
i already asked this question and got answers. bad connection.(s) clean out bulb sockets, also metal tab connections in socket tarnish, after awhile will cause bad connection. the connector tab in socket is copper, copper tarnishes. clean it add new current grease, even scratch it if need be.
Old Apr 10, 2008 | 02:16 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Will do, thanks Willie.
As for the bulbs seeming to be stuck, I should just pull/twist harder?
(I also assume they turn counter-clockwise to come out like any other bulb?)
Old Apr 17, 2008 | 12:22 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Is this really the case? My turn signals usually don't work (but every once in a while decide to come on) and I've replaced the hazard flasher and what Robster66 is saying is the horn relay, both have been called a "turn signal relay" by the auto parts store. Where is the relay/flasher for the turn signals?
PS-my hazards work fine, so its not a problem with the bulbs or the lights themselves.
Old Apr 17, 2008 | 12:37 PM
Car: 92 Camaro RS
Axle/Gears: Stock
see my post called "intermittant blinker problem"....do what I suggest there before u worry about relays etc...
Old Apr 17, 2008 | 02:43 PM
campin1983's Avatar
Hmm, wouldn't have even thought of that one. I'll look to try that out this weekend.
Old Apr 17, 2008 | 07:42 PM
Car: 92 Camaro RS
Axle/Gears: Stock
I think u'll be pleasantly surprised....always try the cheapest (or even free) stuff first, it is often the dumbest thing that makes car parts not work right! LOL
Old Apr 17, 2008 | 08:43 PM
campin1983's Avatar
I hope your right, judging from this thread and many like it, this seems to be a somewhat common, yet extremely irritating problem. I'm just glad some of you have already been through it, it might save me several hours of frustration and loud profanity
Prodigious
Nov 7, 2020 09:23 AM
Fronzizzle
Mar 18, 2019 08:29 PM
dibella989
Sep 1, 2015 04:12 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
