92 v6 camaro dist. to coolpacks
Old Feb 19, 2008 | 04:14 PM
923.4v6's Avatar
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
does anyone know how to change a v6 distributor motor over to cool packs?
Old Feb 19, 2008 | 11:32 PM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Re: 92 v6 camaro dist. to coolpacks
Coil packs? That's a whole new can of worms. If it's the 2.8 though, I know my old corsica had coil packs instead of a dizzy, and it's the same engine mounted transverse instead of longitudinally. You'd need a new computer and possibly harness.
Old Feb 19, 2008 | 11:53 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
ECM is the same, harness is basically the same. You would need a block that has provision for the 3x crank sensor. In addition you need the clippings of the harness that go to the DIS coil pack, a soldering iron, a wiring diagram, and some time.
Vintageracer
Jan 10, 2020 05:33 PM
BADNBLK
Nov 16, 2016 09:12 AM
apo_bailon15
Mar 28, 2016 05:20 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
db057
Aug 22, 2015 08:17 PM
