Turn signal switch
Old Feb 24, 2008 | 11:57 PM
SteveoGTA's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 4.10's
Turn signal switch
Ok i need to change my turn signal switch and my car has the radio controls on the steering wheel but i dont have a radio in the car and im going to change the steering wheel soon can i use the turn signal switch for a car without the radio controls on the steering wheel? i did a search and came up with nothing any help would be great
thanks in advance
Steveo
Old Feb 26, 2008 | 10:02 PM
SteveoGTA's Avatar
Axle/Gears: 4.10's
Re: Turn signal switch
ttt
Old Feb 29, 2008 | 01:58 PM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
Why do you need to change your turn signal switch?
Old Feb 29, 2008 | 05:29 PM
SteveoGTA's Avatar
Axle/Gears: 4.10's
when i hit the turn signal either way they just stay solid already changed all the bulbs, the flasher and cleaned all the connectors its the only other thing i can think of
Old Mar 1, 2008 | 09:43 AM
Car: 1986 Camaro
Engine: 350 v8
im having the same problem with all my driver side lights
Old Mar 3, 2008 | 06:45 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I cant find my flasher.It`s not where the chilton manual says it is or I`m blind.Where was yours?Thanks.Never mind,found it.
Fronzizzle
Mar 18, 2019 08:29 PM
LittleFranks
Sep 17, 2015 12:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
