Hooking up a knock sensor to al ight?
Old Mar 1, 2008 | 05:50 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Just wondered if there was maybe some way to do it...
I figure it might be a useful tuning tool for someone like me who's running a carbureted car to have a knock sensor hooked up to some sort of visual interface instead of an ECM.
Old Mar 1, 2008 | 04:33 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Hooking up a knock sensor to al ight?
Depending on the sensor, you might be able to use a diode, however
the duration and level of the signal will vary and may not have enough
voltage to forward bias the diode in all instances.
The ECM uses complex circuits to read the output as it's a sign wave (AC),
not a DC voltage.
You'll probably need some sort of amplifier and hold circuit (555 timer?) to
make it work.
gta892000
Aug 11, 2019 11:16 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
