key ignition, how to replace?
Old Mar 13, 2008 | 03:36 AM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
I can start the car and shut it off but when you shut it off it will not go in the lock position, hoew much issue is it to replace, Im pretty mechanically inclined or is this something better left to a shop that can do it even tho- there is cost involved?
Old Mar 13, 2008 | 04:48 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Re: key ignition, how to replace?
most locksmiths can do it for about 75.00 or less. they did mine for 40.00 for my 86 iroc. of course if it has a chip in the key then it might be higher. im in florida so prices may vary from place to place
Old Mar 13, 2008 | 09:24 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Try searching the forum for "ignition".
Old Mar 13, 2008 | 10:48 AM
kerplunk318's Avatar
Its really easy, Ive done 2 gm columns and am confident I could do a third in 25 min. you just need a puller for the wheel and the tool that compresses the spring inside the column to allow you to remove the retaining ring.
BRoss99
Aug 10, 2025 05:08 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
92projectcamaro
Aug 6, 2015 01:20 PM
