np opower to fuel pump,or relay
Old Mar 19, 2008 | 07:49 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ok, i've put new fp relay,fuel pump itself, oil sending unit, checked all fuses .even one by fender well. still no power.this car ran fine b4 winter then i've left it alone until this morning. battery tested at 11.98. and it barely cranks car over. nevermind the fuel pump fuse (under hood) was blown now i gotta figure out why it blew.
Last edited by bbsr72; Mar 19, 2008 at 09:28 AM. Reason: misspelling supposed to say no power
Old Mar 19, 2008 | 06:05 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: np opower to fuel pump,or relay
Did you also check the fusible link, which is on the same wire as the FP fuse which was blown? I would check for continuity beween the battery side of the fuseholder, and the positive battery terminal. If there is continuity, check resistance, and see if its excessively high. Also, I would try cleaning the battery terminals.
Old Mar 19, 2008 | 10:55 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ut oh somethings wrong then bcuz mine doesn't have a fusible link, where you described. better put one on it .what size do i need?
Old Mar 20, 2008 | 08:42 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
there is one it was just wrapped up in a bunch of tape. thanx though.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
Kaweh
Aug 9, 2015 02:54 PM
