mechanical or electronic
Old Mar 21, 2008 | 07:10 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
what year firebirds came with a mechanical speedo and electronic speedo.
im lookin to swap out my speedo and tach in my 91 and found a set from an 88 GTA but dont know if it will work. if not, is there anyway to change the mechanical to electronic?
Old Mar 22, 2008 | 05:39 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: mechanical or electronic
86-92 Firebirds got the electronic speedo. 85 was an odd year, because it has the updated dash/interior, but still a mechanical speedo. You can swap to an electronic speedo, but it's a fair amount of work, and you'd need a speed sensor for the trans, as well as a VSS buffer box. Your formula already has an electronic speedo, and the GTA one should work just fine, plug and play. The only thing I'm not 100% sure on is the oil pressure sender, I seem to recall there being a couple different versions of it, for different gauges. If both oil pressure gauges are the same (like 0-30-60), then you should be good to go.
Old Mar 22, 2008 | 11:30 AM
Car: 91 GTA
Axle/Gears: stock
thanks. i appreciate it. thats exactly what i wanted to know.
Old Apr 2, 2008 | 11:40 AM
Car: 91 GTA
Axle/Gears: stock
i just got the speedo and tach in yesterday and i have one more question about it before i install it. does the speedo and/or tach need to be calibrated to show the right speed and rpm? what i mean is, where the needle is located, say at 30 mph, on the 120mph speedo would be slightly different on the 140mph speedo. does this need to be corrected in any way or is it something done in the circuitry of the speedo itself? i was wondering the same thing for the tach.
Old Apr 2, 2008 | 10:27 PM
Car: 91 GTA
Axle/Gears: stock
anybody know?
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
sjorgens
Oct 1, 2015 07:54 PM
anesthes
Sep 30, 2015 07:48 AM
mfp189
Sep 27, 2015 09:25 AM
