(VSS) 89 cluster to 91 ecm
Old Apr 1, 2008 | 10:08 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
what do i need to connect to make things work right
i have a 89 camaro with 700r4, 89 cluster with cable driven speedo.
i'm using a 91 firebird harness with manual tranny, and it had the electric speedo.
my cluster has a brown wire that's supposed to go to ecm's (speed input)
and i know there's a difference in pulse, 2000 to 4000.
i'm lost as to what i need to do.
Old Apr 2, 2008 | 11:16 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: (VSS) 89 cluster to 91 ecm
This is a tough one. So your using your original drivetrain, and putting in a 91 firebird harness and 91 ecm.
I'm thinking you can just use a signal converter box (Dakota Digital SGI5c) put in between your optical sensor on the 89 speedo to the 91 ECM. That'll take care of the computer getting the correct PPM.
I'm assuming that your changing your 89 from MAF to speed density?
Old Apr 2, 2008 | 02:04 PM
matthufham's Avatar
Car: 90 z28
Transmission: t56
right, the 89 camaro had a 2.8/700r4 and we took a 5.0 tpi out of a 91 firebird and got the entire wiring harness
Old Apr 3, 2008 | 09:22 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
ok, well the signal converter box will give the ecm the correct ppm.
They're not very expensive around $70 new.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
