Swapping a manual trans into my auto f body and have a wiring question
Old Apr 6, 2008 | 09:15 PM
GMZombie's Avatar
Car: 89 Camaro RS Convertible
Engine: 355 chevy power
Transmission: 5 speed manual
Axle/Gears: standard
there are at least 2 plugs that i dont think i have one is for the neutral safety switch and one being the clutch indicator light switch? i think on the last one. is there a specific place i can wire into or are there plugs under there for that hat i havent seen yet?
Old Apr 7, 2008 | 07:12 AM
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
Re: Swapping a manual trans into my auto f body and have a wiring question
By Netural safety do you mean the switch that keeps the car from starting unless the clutch is pressed?
I just removed the Park neutral switch(attatched to the auto shifter) from the consloe and connected the large two wires to my clutch switch using just regualr spade connectors.
I looked under the dash of my '83 for a plug in for the manual tranny to connect the clutch switch to but could not find anything so I decided on this plan on action.
I am unsure about the clutch indicator light.
Old Apr 10, 2008 | 08:39 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
I Just wired the two wires together I just make sure its in neutral before I start it
My Question is about the Trunk switch. How do I wire it up so it doesn't pop while i'm going down the road? It hasn't yet but it is a worry.
I've thought about wiring it to the E-brake. but I'm wondering, how is it wired in a stock manual 3rdgen?
Old Apr 10, 2008 | 09:34 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You guessed it, they wire the hatch release to the e-brake on manuals.
Lou
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
reiderz iroc
Aug 13, 2015 04:57 PM
cRoe4
Aug 7, 2015 08:46 PM
