What is this sensor?
Car: 89 Z28
Engine: 305 TBI
Transmission: B&M 5-speed
Axle/Gears: corvette gears in tranny
I have a 1989 camaro with a TBI 305. There is a sensor in the block in between the spark plugs on the passenger side of the car. The sensor has been melted and the wires have been melted apart. What is this sensor so I know which part to get to replace it with?
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
Re: What is this sensor?
yup he is right, the wires to that sensor usually melt due to the proximity of the exhaust manifolds. go to www.rockauto.com you can get it there.
Car: 89 Z28
Engine: 305 TBI
K my temp guage still works as well as my coolant fan, but I will def replace that asap...Is there more than one sensor that regulates temp? also I have a problem with voltage...when the ignition switch is on, but the car is not running my voltometer in the dash reads around 9-10v. I believe it should read 12 and this causes problems with my starter, it either works fine or isn't able to pull enough power from the battery to turn the starter motor, but when the car is running it reads around 13-14v. What could be causing the shortage of power?
Car: 1988 gta-
Engine: 383 tpi
listen am not really good as far as electricity goes but is everything off when you open the key ? radio? defroster? a/c heater fan?
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
9- 10 volts is a touch low but really close to normal. You have to keep in mind that a 12 volt battery is not going to read dead nuts 12 volts when in your car. You have ECM back up memory to mantain, radio memory, cigarette lighter, brake light switch is always HOT, and a few other things have relays which use HOT wire AND switched signal source like electric fans, some headlight systems, properly installed fog lights, etc.
There is a KNOCK sensor on some vehicles on the passenger side, but I am used to seeing that mounted lower in the block not up on the head, but what the heck, yours is melted right. Thats not normal what ever it goes too.
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Car: 89 Z28
Engine: 305 TBI
I figured out the voltage problem...bad connection on the neutral switch. I have an aftermarket tranny n the wiring was loose. Its definitely the coolant fan switch because i tested the fan and it doesnt turn on anymore. I mostly use the car at highway speeds so the fan hasnt been needed apparently because it never overheated til i just ran it and parked to idle for a little while to see what happens. Thanks for the help tho
HoosierinWA
Oct 7, 2015 10:15 AM
