Horn relay test question
Old Apr 8, 2008 | 02:13 PM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
I found this and tested it as written:
check the ohms, should be between 10 and 20 ohms, middle terminal (A) is where you apply voltage then use one of the others to ground the coil.
I took the relay out and measured from connection A to B (from +12V to the connection where the horn switch would be) and got 40 ohms. Does this mean that the relay is bad???
Thanks for the help!!!
Old Apr 9, 2008 | 09:15 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Horn relay test question
Are these the instructions for that relay specifically?
If not, then the resistance might be correct.
The main question is: does the relay actuate when you put 12V on it? That's the ultimate test.
Lou
Old Apr 9, 2008 | 03:34 PM
Car: '91 Z28
Engine: LB9
Thats what I found in an other thread regarding the horn relay but I will check the other things too next weekend.
Old Apr 12, 2008 | 11:57 AM
Car: '91 Z28
Engine: LB9
Ok, finally had the time for some further test. There is no current coming from the buttons when applied. However the buttons still make a "click" while pushing, so I'm not sure if the problem are the buttons.
How does the current flow to the buttons and on to the horn relays? Probably there is something to check too?
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
