Jacobs Ignition Help
Old Apr 22, 2008 | 06:38 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
I am about to install the Jacob's Electronics FC1000 ignition, and I got all of the connections figured out except for one... in the instructions there are three wires, a Orange and Purple one twisted together, and a Green Wire.
The Orange and Purple twisted one, direct from them:
"These wires are routed together in one harness to form the Magnetic Pickup connector. It will connect to factory pickups or other aftermarket pickups. The Orange wire is positive (+) and the Purple is negative (-). When these wires are used, the Green wire is not used. NOTE: the magnetic pickup cannot be used with vehicles equipped with factory fuel injection!"
The Green wire is, direct from them:
"This wire is used to connect to the points, electronic ignition amplifier output or the Yellow wire of a Timing Accessory. When this wire is used, the Magnetic Pickup connector is not used."
From what I understand, I use the Green wire with my FACTORY TPI set-up correct? And if this is the case, what does it connect to off of my distributor, which is a 1985 INTERNAL coil HEI?
Thanks for all the help fellas,
Brett
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
