Has Anybody seen this Before?
Old Apr 23, 2008 | 09:35 PM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Transmission: 5spd Auto /700R
I started my 87 IROC tonight and I tried to turn on the headlights, but no lights, only the tone like when you shut off the car with the lights on. That's when I noticed that the tachometer, oil pressure gage and voltmeter were inoperative. Interior lights all worked fine as well as the radio and power windows. A quick look in the engine compartment showed the alternator belt and wiring were good to go. I had to get to work so I couldn't trouble shoot. Any ideas as to what's wrong?
Geno.
Old Apr 24, 2008 | 12:54 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: Has Anybody seen this Before?
I would check the fuses.
Old Apr 24, 2008 | 02:40 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
also check your fusible links at the starter.
Old Apr 24, 2008 | 09:26 PM
thedude's Avatar
Car: 85 Trans Am
Engine: LG4
I agree with the fusible links. There should be two of them. It's been a while since I've seen a diagram, but I believe one controls all the circuits you mentioned.
I have one go and it was the opposite of what you mentioned. Nothing worked but the lights. So its possible that the other one went out for you.
Old Apr 25, 2008 | 01:07 AM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Thanks, Guys. I lucked out on this one. Found two bad 10 amp fuses. Replaced the fuses and problem solved.
Geno.
