electric windows not working
Old Apr 28, 2008 | 07:27 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
is there a relay somewhere on 3rd gens for the electric windows?
i have power going into and out of my switch, but not at my window motor.
Old Apr 28, 2008 | 08:11 AM
iansmusical's Avatar
Car: 91 Firebird & 02 VW Polo TDI
Engine: 3.1 V6 & 1.4 3 cylinder
Transmission: Auto, M5
Axle/Gears: Stock
Re: electric windows not working
Don't quote me but I don't think 3rd gens use separate relays on the window motors. The switches go straight into the window module, which may have a relay in it... not sure!? Presuming the fuse hasn't blown ;-) it might be just easier to swap the module/motor!
Old Apr 28, 2008 | 08:24 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
fuses are good.
the plug going into the motor coming out of the car is dead.
i had to put different doors on the car, i was thinking i had a bad window motor but i tested the plug going to the motor, nothing!
Old Apr 29, 2008 | 12:17 PM
Axle/Gears: Stock
It could be just a bad connection or broken wire. I've attached the wiring diagram for a Firebird but I'm not sure if it's the same as a Camaro :-)
Old Apr 29, 2008 | 01:22 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
thanks, i bet that my 35a fuses are blown.
Old Apr 29, 2008 | 04:20 PM
Axle/Gears: Stock
The fuse is easy to check but if it has blown, then it was for a reason! As there is no motor control module you could isolate the motor and test straight from the battery. After that it's a case of measuring voltage at various wire points, it's not a complicated circuit.
Old Apr 30, 2008 | 07:16 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
thanks for the diagram.
if my fuse was blown, would i have power at my switch?
i'll change it regardless because it's the easiest thing to do.
i just got my car running. the car hasnt been driven 1500 miles since 02, they are probably the original fuses from 86. i'm praying they were just old.
either way, i have this huge bundle of wires tucked under neath my fender, because i'm afraid to cut any of them. the problem could be in those wires.
by the way, i removed a little relay beside my brake booster before i painted the engine bay, could this be the problem?
Old Apr 30, 2008 | 07:31 AM
Axle/Gears: Stock
From just looking at the diagram myself ;-) if the fuse had blown there would be no power to the switches. The circuit is really simple to follow... from fuse 12v goes to each power window switch and depending which way you push it effectively reverses the polarity of the motor. You're gonna have to trace the wires in the door itself as there is only one coming into the door, that's the 12v one.
It won't harm to change the fuses anyway as they do oxidise etc.
There is likely to be a load of wires under the dash etc but for the windows you don't need to worry about them, just deal with what's in the door itself. Try the motor separately as this then rules that out and leaves you with a wiring issue.
The relay near the brake booster isn't window related... could be fuel pump, flasher etc.
Oh think the windows will only work if the ignition is on!
Hope that helps.
Ian
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
stalkier
Aug 13, 2015 12:59 PM
