Help! VATS bypass didn't work
Old Apr 28, 2008 | 08:35 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Two weeks ago my 91 RS wouldn't start. Based on various posts on here, I figured out it was the VATS. I rigged a bypass using resistors as in the Tech Article. It worked instantly, but a week later the car began refusing to start again. Same as before. No noise, nothing. When I turn the key the Security light comes on for a few seconds then goes out. I turn the key to OFF, then back to start and the light comes on again for a few secs, then goes out.
I pulled my resistor pack out and measured the resistance. It was slightly higher than when I put it in (outside air temps have risen?), so I made a new resistor pack and got the exact value of my key (5.82 kohms). I put it in and still nothing.
I am at a loss as too what to do now. I can't even start the car to give up and take it to a shop.
And even worse I'm heading to Panama City soon and I've been looking forward to cruising the strip in my vert. Anybody got ideas to get me back on the road?
Old Apr 29, 2008 | 08:52 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Help! VATS bypass didn't work
If the security light does not stay on, your VATS isn't the problem then.
What do you mean by "no noice, nothing"? Could you elaborate on that? It could easily be anything else, like the starter or ignition cylinder.
Lou
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
Leggman1
Aug 6, 2015 04:15 AM
