TA driving light issue
Old May 2, 2008 | 02:33 PM
jordeezy's Avatar
Car: 1985 Trans Am
Engine: 305 LG4 boat anchor
Axle/Gears: 3.27 "Down Under" 9-Bolt
OK, my TA's front pass side amber driving light does not come on when i hit the switch for it. It does not come on when the headlights are up either. In both of these cases, the pass turn signal on my dash stays lit. It does function correctly as a turn signal though.
I've changed the bulbs already, and still the same issue - I've got a blinker, but no steady driving light. I've also replaced the flasher (probably unrelated).
Any ideas? My guess is a relay, I've been replacing a bunch of those lately.
Old May 3, 2008 | 12:50 AM
iansmusical's Avatar
Car: 91 Firebird & 02 VW Polo TDI
Engine: 3.1 V6 & 1.4 3 cylinder
Transmission: Auto, M5
Axle/Gears: Stock
Re: TA driving light issue
My guess is that you've got a wiring issue as obviously there should be 12v to the light when either the others or headlights are on. The turn signal will also put 12v there but from another source.
Just looked at the wiring diagram and it appears you have two bulbs in the parking lights, one is the parking light and the other a turn repeater.
I'd be tempted to check the wiring with a volt meter and the various stages etc.
Old May 3, 2008 | 03:23 AM
jordeezy's Avatar
Car: 1985 Trans Am
i'll check the voltage tomorrow. thanks.
Old May 3, 2008 | 07:05 AM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Sounds like you probably have a bad socket. Check for power on the appropriate wire with a test light.It should light brightly, if not check an inch or so from the socket.
Old May 3, 2008 | 10:43 AM
jordeezy's Avatar
Car: 1985 Trans Am
No, theres only 1 bulb for the front amber driving lights.
Right on the money bgood, I just disconnected and reconnected the wires to the socket, and it started working again. I guess there was just a loose connection somewhere.
Thanks for all your help fellas!
Old May 3, 2008 | 08:55 PM
bgood71's Avatar
Car: 89 GTA
No prob buddy, thats why we respond to posts.
by the way...cool avatar
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Wade787b
Sep 29, 2015 01:15 PM
Omega
Aug 10, 2015 12:46 PM
