has any body done this?
Old May 3, 2008 | 08:49 PM
Chillenaj's Avatar
Car: 1991 Camaro convertable
Engine: 305 T.P.I.
Transmission: 700 r4
Axle/Gears: stoCk
HEy all i was wondering i have a 91 Z 350 convertable, i would like to re wire the hole damnthing cause i have a lot of loose wires and stuff, but i dont know if i wana have some one do it ,(how much would that cost?) but i think it needs to be done is there any way to find out whats needed and not?
THakx yll
Laer adaM
Old May 4, 2008 | 12:31 AM
sikZ28's Avatar
Car: 86 Trans Am
Re: has any body done this?
yes, I am in the process of re-wiring my IROC, and this is what I have to say on this subject...
either have it professionally done (by a place that specializes in harness making/auto wiring and such, not just the garage down the street)
which can and will run into some big bucks.
Or you can spend a good deal of time and a buttload of patience in order to make it right the first time you do it because you don't want to have to go back and chase down a loose connection all because of a bad crimp or bad soldering job.
It is a big job rewiring a vehicle, mine is fuel injected, seems like there are a ton of sensors and plugs, so take notes and draw diagrams if needed, learn to make solid crimps and solder joints.
And make the new crimps and joints water tight, put some shrink tubes over them so water can not get into them a start the oxidizing and corroding process.
And make sure the wiring is secured from anything that might melt it.
There is of course so much more I could go into about this, but what I have said here gives you an idea.
Sorry if it seems I am just rambling on and on and this reply looks like it was written by a circus monkey, but I just worked almost 80 hrs this week and I am pretty much wiped out.
Just my
Mike.
PS
I might edit this tomorrow after I get some needed rest.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Kenwood
Sep 4, 2015 05:50 PM
