Module mounted under hood latch
Old May 4, 2008 | 09:07 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Anyone know what this is? I'm going to remove the brace, and I'm not sure if I need this thing or not.
Old May 4, 2008 | 09:17 PM
sikZ28's Avatar
Car: 86 Trans Am
Re: Module mounted under hood latch
did you forget the pic?
Old May 6, 2008 | 03:25 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
whoops.
Old May 6, 2008 | 05:42 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
If it's in a 90-92, it looks like the front sensor for the airbag system. don't touch it if you don't want the airbag system breaking/airbag going off.
Old May 6, 2008 | 07:09 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
My car never had airbags though......its a 91.
Old May 6, 2008 | 08:36 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Correct, this is definitely the front airbag sensor. Don't worry, it won't deploy the airbag accidentaly. The system is pretty safe.
Did your car never have airbags or did somebody maybe replace the steering wheel in the past? I've seen people do it a lot. You can check your RPO codes.
Lou
Old May 6, 2008 | 10:57 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
When I got it, it had a factory camaro steering wheel on it. I don't think it ever had one, but I'll look at the codes.
Old May 6, 2008 | 11:49 PM
All 90-92 camaros had a driver's side airbag. the wheel was replaced.
Old May 7, 2008 | 12:06 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Weird. Never would've guessed. Thats the first though that came to my head though. Surely this car never had airbags, I said. So guess I'm ripping it out.
Oh, the car was in an accident before I bought it in Germany from a German. He probably set it off, and just put a cheaper wheel on it....
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Randomtask2
Aug 13, 2015 01:57 AM
