Help Identifying a Wire
Old May 14, 2008 | 08:50 AM
flyfirebirdfly's Avatar
Car: '91 V6 Firebird
Engine: V6 Chevy 3.1 (modified bore)
I found a disconnected wire coming through the firewall, routed to somewhere near the battery. It is a single black wire with a yellow rubber end crimped to a "C" screw ring.
I'm having starting problems. It's doubtful this has anything to do with it but I'm checking everything.
Old May 16, 2008 | 12:57 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Help Identifying a Wire
go on the other side of the firewall and see if you cant trace it down, there is always the chance that somebody did a hillrod attempt at an amplifier install and just left the wire. its not the typical color for amp wire nor does it have a fuse but ive seen people cut the end off of extension cords and use them for power wire, so its true what they say about it taking all kinds.
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
