f/p kicks on when i hit wdw sw.?
Old May 15, 2008 | 11:33 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
trying to get electric wndw to work ( still don't) ,anyway when i use the wdw switch (drivers side only ) the fuel pump turns on? whats up w/ that?
Old May 15, 2008 | 01:58 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: f/p kicks on when i hit wdw sw.?
The power window and fuel pump wiring run alongside under the carpet, next to the driver side door. Not for long, just a foot or so. One possible explanation is that a screw went through the wires and shorted them together.
I'd pull the driver side door sil plate, lift the carpet by the seat and check out the wire bundles.
Lou
Old May 15, 2008 | 02:09 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Wait, so do you have to hold the window switch to keep the car running? lol
Old May 15, 2008 | 02:43 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Old May 15, 2008 | 07:09 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well, campin, when this car is done i invite you to bring it on .
Old May 16, 2008 | 12:41 AM
wife hates it's Avatar
another place that you might check is the block switch below the brake booster on the fire wall have had false shorts in that block on mine.
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
tattmann
Sep 27, 2015 05:20 PM
