pwr window switch on fire
Old May 17, 2008 | 03:02 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
put brand new motor on my pass. side window rolled window up and down all day because i couldn't believe how easy it really was to change it. then just now the switch started smoking real bad. what now ,and why didn't the fuse pop or something.
Old May 17, 2008 | 08:23 PM
Alaska Hwy 1Le's Avatar
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
Re: pwr window switch on fire
I thought i needed a new motor for my window to but I found the wires coming from the switch fell out of the little clip holding them in position. My emergency brake was pinching the wire and almost cut it. It would short and start to smoke to. replaced switch and fixed wire then all was OK. Maybe just check in there. Or maybe you were just zippin the window up/down too much and the continuous load was just to much. I don't know if that helps any but good luck none the less.
I'd unhook the battery at night just to be safe cuz if the switch melted it could keep flowing current and burn the car down.
Old May 18, 2008 | 10:43 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
when i went back out to look at it this morning i can see that the ground is what got hot
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
