1991 Camaro RS won't start ?
Old May 26, 2008 | 09:56 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
I am getting 12 volts to the starter, to the alternator, and to the battery. I jumped a wire in the diagnostics port to see if there are any codes that might be causing this problem and sure enough, I counted the number of flashes and I have a code "53". My Chiltons book repair manual codes only go up to 48. Does anyone know what code 53 is and if there is any relevance as to why it won't start... does not even crank. Thanks all .
Old May 26, 2008 | 10:23 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: 1991 Camaro RS won't start ?
ANYONE ???
Old May 26, 2008 | 10:28 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Overvoltage condition
OR
EGR system problems or EGR #1 solenoid
OR
Voltage reference error
OR
VATS problem
I'd be willing to guess that your problem is with the VATS, since IIRC all since 89 have VATS and when not working will kill the fuel pump and ignition.
Old May 26, 2008 | 10:33 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
OR
OR
OR
VATS problem
Thank you for the reply, I'd be willing to bet it would be the VATS as well. Will try and check on that asap. Is that associated with the code 53 that I am getting, or is it something else ?
Old May 26, 2008 | 10:44 PM
Al Hasse's Avatar
I bought myself a code reader years ago (before I knew of the jumper trick) and of course it came with a book with the codes. Those I listed for Code 53 was for every GM car with the same connector (or so I'm told by others in the know). Discard what you know your car doesn't have, then go from there.
No crank to me sounds like VATS with Code 53. I would also expect the Security light on the dash to be on for a VATS problem, but it might not.
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
