Fan Relay question
Old May 27, 2008 | 07:00 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
Fan Relay question
Is it ok to have the computer wires hooked directly into the fan relays and not going threw the ignition?
Old May 28, 2008 | 10:54 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Re: Fan Relay question
anyone?
Old May 29, 2008 | 11:59 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
You need to be a little more specific.
What computer wires exactly?
The only wire that the computer uses to control the primary fan relay is the dark green/white wire. That is the only wire you should be using to turn on the fan.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
