gauge wires
Old Jun 6, 2008 | 12:36 AM
89maroconvrs's Avatar
gauge wires
hi i recently did a tbi to carb swap and the motor i have in the car now is a 79 camaro 350 block. I was sondering by chance that someone might know the colors of the wires and what connector for the temp gauge, oil pressure gauge. And also i noticed that the brown/white stripe wire that is for the volt gauge runs to one of the relays is there neway to bypass that since im not gonna be using that relay?? o ya its a 89 camaro rs if that makes a diff. thanks
Old Jun 6, 2008 | 10:25 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: gauge wires
The temp gauge uses a dark green wire, on the driver side of the engine, it is normally connected to a sensor between the first two sparkplugs.
The oil pressure gauge is on top of the block, in the very back, driver side. Uses a tan wire.
You can see more here: http://www.austinthirdgen.org/mkport...uges_part1.gif
More diagrams can be found here: http://www.austinthirdgen.org/index.php?pid=19
Hope this helps.
Lou
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
