Signal flasher?? where is it??
Old Jun 18, 2008 | 06:51 PM
dukie's Avatar
I have a worn out signal flasher on my 88 camaro.. I have the underside of the dash taken appart and can find the 4 way flasher in the Convience panel, but I can't seem to find the turn signal flasher..
I have found the horn relay and the buzzer to the keys and lights on..
Am I missing something??
Please help..
Thanks in advance..
Also posted in the convertables sorry for any confusion..
Old Jun 18, 2008 | 08:08 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Signal flasher?? where is it??
My Haynes manual says something about them being located in the rear of the fuse box...
"The hazard flasher and turn signal flasher are mounted either at the rear of the fuse box or at the convienience center located under the center of the dash."
Old Jun 18, 2008 | 08:14 PM
dukie's Avatar
I've been into both of those.. found the hazzard flasher but no turn signal flasher...I am at a loss. This is usually easy to find and fix..
Old Jun 23, 2008 | 08:32 PM
dukie's Avatar
HOLY S&*# You have to be a hungarian contortionist to find that thing..
Well tonight success! it is ABOVE the conv. panel strapped to a support member.. Tough to find but now it is great...
I am going to cruise it tomorrow night..
I would go out tonight but it is raining....
Thanks for the help.
InfernalVortex
Apr 20, 2021 11:31 AM
Fronzizzle
Feb 9, 2017 09:31 AM
thunder57
Nov 7, 2015 02:28 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
