heat and ac problem
Old Jun 18, 2008 | 09:01 PM
morg man's Avatar
Car: 89 Formula 350
Engine: TPI 350
Axle/Gears: 3.27s for now
heat and ac problem
does anybody know why no matter where I put the lever on my heat/ac control it comes out the defrost. Has anybody had this problem? The temp control works but I can't get the air to go anywhere but the defrost. I need help on this one. Thanks
Old Jun 20, 2008 | 09:52 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: heat and ac problem
You might have a problem inthe vacuum distribution system. Either the controls or the vacuum diaphragms. Do you hear any hissing from inside the dash?
Lou
Old Jun 20, 2008 | 10:41 PM
morg man's Avatar
Car: 89 Formula 350
Engine: TPI 350
I put my ear to it this evening and I dont hear any hissing. I pulled the whole unit out of the dash. The lever still makes the thing rotate from point to point(that little round thing with all the vaccum lines comin out of it). But I still only have defrost. I even unhooked all the lines just to see what it would do, and still only have defrost.
Old Jun 21, 2008 | 09:24 AM
BigBadLou's Avatar
Engine: TPI
I'd check if you have any vacuum in the lines at all. You might have a broken line in the engine compartment, not allowing any vacuum to enter under the dash.
Lou
Old Jun 21, 2008 | 09:35 AM
vwdave's Avatar
My money is the vacumn line in the engine bay.
(Corrected)
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
chazman
Aug 22, 2015 02:01 PM
