NO POWER AT HATCH MOTOR
Old Jun 11, 2008 | 07:55 PM
my1987z28's Avatar
DOES ANYONE KNOW WHERE I CAN GET A WIRING DIAGRAM TO CHECK THE WIRING AT THE PULL DOWN MOTOR FOR POWER? Thanks
Old Jun 11, 2008 | 08:53 PM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: NO POWER AT HATCH MOTOR
http://www.austinthirdgen.org/index.php?pid=19
Old Jun 11, 2008 | 08:58 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Their is one solid orange wire that runs from the back of the hatch to the fuse pannle( it runns along the driver side of the car) wihch is your power wire.
also check the fuse for it.( if i remeber corectly its the row farthest from the drive 2nd or 3rd one in.
Old Jun 11, 2008 | 09:15 PM
Pop45398's Avatar
Car: '91 RS
Axle/Gears: 3:42
An '87 Helms factory service manual shows it as a red/white wire but had a buddy look at his '87 and his is orange, wtf?
Old Jun 11, 2008 | 10:01 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
i have a 87' im just letting you know what I have found after hours of trobleshooting . mabe different years are different
Old Jun 11, 2008 | 11:42 PM
Pop45398's Avatar
Car: '91 RS
Axle/Gears: 3:42
What different years? I have an 87 GM factory Camaro service manual (printed by Helms and is actually two books, one is strictly electrical, the other driveability and emissions), not a Haynes or other cheap manual. This cost $90 back in '87, ordered from my local Chevrolet dealer. The colored schematic shows a red/white wire and has written next to it "red/wht" but your '87 and my buddy's '87 both have orange wires feeding power to the hatch pull-down. I'm saying the factory service manual is wrong.
Old Jun 12, 2008 | 08:21 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
o ok sounds good then
Old Jun 12, 2008 | 05:28 PM
my1987z28's Avatar
thanks - i will check the wire tonight - i have checked the fuses and all were good - i am getting pretty tired of having to keep a 50LB bag of sand on the hatch , just to keep it down!
can i just run a jumper wire from the battery to the orange wire to power the hatch motor back up?
Old Jun 12, 2008 | 10:28 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
are the fuses good ( the ones by the hatch...the big block looking one?) might wana check them out and also see if you have everythign hooked up right.......what you also can do is contact Lon at tds( top down solution) wich i think is a sponsor hes amazing with those thing.
Old Jun 13, 2008 | 11:49 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have an '87 350 IROCZ, its 21 years old. Sometimes my hatch motor does not work either but its always an issue with corrosion with the tabs & contacts.
Old Jun 14, 2008 | 07:59 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
with corrosion on the tabs just take a metal brush and scrape em up abit
Old Jun 14, 2008 | 11:48 PM
Vanilla Sky's Avatar
What fuses by the hatch? Am I missing something?
I have a motor that turns, nothing worn out, getting power, but the pulldown isn't working as it should. I'm going to start tracing wires tomorrow.
It was in really good condition, outside of the worn brushes and crushed shell sand from the beach. I'm just hoping the controller isn't dead.
After looking into it, what I'm calling the controller is the reversing switch.
Old Jun 15, 2008 | 12:58 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
It's a relay, my bad here is a pic of what it looks like http://www.top-downsolutions.com/popup_image.php?pID=59 it might be gray or black
In this pic it's the lil black box one the far right side( its connected to the wire harness part.
http://www.top-downsolutions.com/popup_image.php?pID=51
Old Jun 15, 2008 | 12:08 PM
I have a 92, and I did replace the relay back there. The only other thing I can think of is this controller thing that mounts to the unit.
edit
I took the controller thing apart, and it looks to be nothing more than a switch. I cleaned it out, but still the same. I'm thinking about replacing it for good measure, since it was rather corroded, and there's some corrosion I can't clean.
Is there any real controller, or is it just a series of switches and relays that control the pulldown? If it's just switches and relays, then man, what were they smoking? I can see that being the case when the first third gens rolled off of the assembly line, but 10 years later? They changed everything else, why couldn't they change the controller?
edit 2
Even though the brushes look fine, they aren't long enough, so I'm not getting contact at the motor's armature. That's next on my list.
edit 3
So I can't find brushes. I've pulled apart every electric motor from my Honda, not finding a brush in the correct shape. I'm hoping to find what I need soon.
edit 4
I found brushes that I think will work. After I test that they work, I'll put up the part numbers, and possibly start rebuilding the motors for resale as another solution to a burned up motor.
Last edited by Vanilla Sky; Jun 15, 2008 at 10:22 PM. Reason: spelling, adding additional info
Old Jun 15, 2008 | 11:36 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
I would sugest contacting TDS , Lon will walk you though what neeeds to be done. I was on the phone with him for like 40 mins troble shooting mine and rebuilding it.. he is a good guy and has good advise
Old Jun 16, 2008 | 01:40 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
There's a bit of misinformation in this thraed. The hot wire for the pull-down unit for all years is a red with white stripe wire. It connects to the blue wire of the pull-down wiring harness. The orange wire your friend traced it power to the rear hatch light.
Second bit of misinformation is suggesting to clean the metal contacts on the pad to the left of the pull-down motor. Cleaning this contacts won't cause any harm, but that contact pad has absolutely nothing to do with the pull-down unit. That pad powers the HMSL (high-mount stop light).
Lon Salgren
Old Jun 17, 2008 | 12:42 AM
I spend 8+ hours a day on the phone with people trying to get their DSL back up and running. I'd rather not spend time on the phone that I don't have to. My cell phone gets used maybe 30 minutes out of the whole month.
I'm still waiting for motor brushes. They cost me all of $4, so no big deal if they don't fit or need modifications to fit. I'll keep everyone updated and if all goes well, I'll write a tech article for the motor rebuild.
Old Jun 21, 2008 | 10:28 AM
Brushes didn't help, and I'm suspecting my armature overheated and is shorting out. Probably should take it all back apart and bench test this thing.
With all of that being said, I'm on the lookout for a new pulldown. If I can't find one locally, I'll be getting in contact with Lon.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
