alt. wireing
Old Jun 19, 2008 | 07:37 PM
carbediroc's Avatar
alt. wireing
I have an 85 iroc the wireing has been hacked up beyond beliefe but I am getting it worked out it is driveable now but my problem is the altenater does not charge till I rev the motor a little its like it turns it on then its fine till I shut it off any ideas would be great thanks
Old Jun 19, 2008 | 11:04 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: alt. wireing
sounds like a 1 wire alternator to me. the stock 3 wire ones are "self exciting" meaning they start charging as soon as the motor kicks over- that's what the extra 2 wires are for. the one wire alternators are NOT "self exciting" and need to be spun at a certain RPM before they start charging. if it starts charging after you rev it a little, it's most likely a 1 wire. or you can see how many wires are hooked up to it and that'll give you an answer.
Old Jun 20, 2008 | 12:02 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: alt. wireing
You need to run a jumper wire form the A terminal to the battery post. See link bellow.
http://www.geocities.com/vtcamaro/Pi...rams/pg137.jpg
Old Jun 20, 2008 | 01:41 PM
carbediroc's Avatar
Re: alt. wireing
thanks guys I ran the jumper and that solved it it is a three wire but I just ran it like a one wire becuse there was no wireing left
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
