Fog light switch
Old Jun 22, 2008 | 03:37 PM
George90GTA's Avatar
Car: 1990 GTA
Engine: 355
Fog light switch
Does the switch stay to the right when you press it to turn it on?
Mine does not. It rocks back and will not stay on.
Old Jun 28, 2008 | 12:14 AM
Firebat's Avatar
Re: Fog light switch
90-92 Firebird foglight switches are the same. It shouldn't rock back, something is not right. First, try taking the switch out, maybe there is something stuck in there or near it thats not letting it move. Still no go, then try taking it apart. If its beyond repair or can't be taken apart without destroying it, then start looking for a used/new replacement
Old Jun 28, 2008 | 12:50 AM
Stephen's Avatar
Car: 87 GTA
Souds like the On/Off detent inside the switch, is broken or worn out, not allowingthe detent to "lock" in place. Or some piece of dirt is inside the detent "socket", not allowing the switch tab to fit in & stay.
Pull the switch, and see if you can find the detent & what's going on.
Old Jun 29, 2008 | 12:15 AM
Car: 1990 GTA
Engine: 355
Thanks for the reply!
I found a $5 switch for a 90-92 at the local jyard. My switch had plastic tabs at each end that frictioned into detents. One of them was missing.
The switch I recieved sounds like what you described. It is like a spring ball plunger set up. Mine was probably re-engineered based on multiple failures.
Thanks for your help!!!!
jaridjohn
Jul 8, 2024 03:49 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Pilotrick50
Sep 2, 2015 12:48 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
mustangman65_79
Aug 12, 2015 06:39 AM
