CFI to TPI
Old Jun 22, 2008 | 06:30 PM
mike_23us's Avatar
Car: 83' Z-28 CFI, 01' Camaro V-6
CFI to TPI
I have a 83 Z-28 with CFI and am thinking about morphing the fuel system to an OEM TPI unit. It's just at the though process at the moment but is the PCM and harness a hassle free swap or are there issues that I should know to address before hand. Thank you for any information. Mikey
Old Jun 22, 2008 | 09:48 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: CFI to TPI
I'm doing an 88 305 TBI swap in my 85 Trans Am that originally had a 305 TPI engine. This is because the previous owner pulled the TPI stuff off the car and cut out 85% of the harness before I got it and I wanted the easiest route to getting FI back in the car.
From what I found it's a pretty straight forward swap providing you use the engine AND dash harness that came from the donor car. This is mostly because some pin-outs changed places on the bulkhead and underdash plug through the years.
If it were me I would try to find a cable driven speedo TPI system from the latest year camaro before it went to a digital speedometer and go from there. You can install a transmission mounted speed sensor instead of using a speedo mounted sensor.
There are a few ways you can do this and I'm sure others will chime in....but going from F-body to F-body that's the way I would do it.
I installed Speed density TPI on my 82 corvette that originally had a cross-fire engine....but I added a aftermarket stand alone TPI harness into my car.
Good luck
Old Jun 22, 2008 | 11:19 PM
mike_23us's Avatar
Re: CFI to TPI
hey thanks for the input its greatly apperciatied. mikey
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
