Taplock wiring question?
Old Jun 23, 2008 | 08:01 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Bought this:
http://www.taplock.com/
I've locked my keys in my car. Its got power since the box clicks when it activates. The problem is that there are two blue wires which are supposed to send the pulse to unlock the car. I've tries tapping into the switch and the actuator, neither work.
It says that one blue wire goes to the "up-lock wire for actuating the lock" and the other is "to either ground or to 12+v, depending if a ground pulse or negative pulse is sent to the door up-lock".
I'm not sure what to make of this. As I understand it is that one of the blue wires is for a ground, there is no distinction between the two blue wires BTW. Any points in the right direction would be greatly appreciated.
Old Jun 23, 2008 | 08:06 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Taplock wiring question?
that sucks!
Did you try sending 12 volts to the other blue wire?
Old Jun 25, 2008 | 10:21 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Originally Posted by TIMMYS89GTA
that sucks!
I get nothing from either wire, one may be a ground. I sent them an email asking about how to properly wire it up and they told me basically that they only give proper instrutions to certified installers.
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
