Rear hatch release and retract
Old Jun 28, 2008 | 05:28 PM
mz piggy's Avatar
my rear hatch won't release or retract automatically. I checked the fuse, its good. Ran a lead wire to the motor directly and it functions both up and down. Help???
Old Jun 28, 2008 | 09:56 PM
camaro42's Avatar
Car: 1988 camaro sport coupe
Engine: 350 (400 sb in the works)
Transmission: 5 speed Manual
Re: Rear hatch release and retract
i'm having the same issue, but mine is stuck down so i can't even get to the motor because the plastic covering is screwed on where i can't get to. if you can get to your pulldown motor then you should be able to search the message boards for more things you can check. it's a super common problem and there are tons of threads with information.
Old Jul 2, 2008 | 10:07 PM
mz piggy's Avatar
can you not open your hatch with the key? That is how I got mine open to the motor, but now that it is open I can't get it to close, somehow I would rather it be closed than open. I was only able to get it to latch a bit but it won't retract down.Do you have any idea how to fix the problem
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
