Autometer oil press guage wiring
Old Jul 1, 2008 | 07:24 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Im adding an autometer oil pressure gauge to my car. Auto meter supplies a sender for the gauge but I have no open ports to put it in. Where my oil pressure switch would normally go is pluged so the switch is located at the back of the block under the dizzy. Can I tap into the wires for the factory oil pressure switch to run my autometer gauge?
Matt
Old Jul 1, 2008 | 09:01 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
Re: Autometer oil press guage wiring
above the oil filter are a couple of plugs that you can remove and get oil press. but you can use the one behind the distributor that is where i ran mine. i am using the stock one. but it works well. on my truck it was hooked up to one of the plugs above the oil filter.
Old Jul 1, 2008 | 09:03 PM
Your just helpin me out all over huh. The holes are are actually plugged above the filter. Theres nothing to turn to get the plug out. I used the hole at the back under the dizzy for the pressure switch and Im hoping to just use those wires to run the autometer gauge.
Matt
Ghettobird52
Jul 5, 2024 11:18 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
