Some 91 relay questions
Old Jul 10, 2008 | 06:38 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
I need to know what the red wire on the fuel pump relay goes to.
Also, the secondary fan relay, what does the grey wire go to other than the sensor on the A/C? What is the function of that sensor? (it looks like the low pressure side)
Old Jul 10, 2008 | 07:10 PM
BCdawg57's Avatar
Re: Some 91 relay questions
Ok,
I am swapping in an LT1 and i have a new engine harness from speartech.
The grey wire i am refering to is on the "heavy duty cooling" fan relay.
On the original 305 harness i know the wire went to the ECM and also to te fan a/c pressure switch(that switch i was refering to).
Obviously i no longer will be running a ECM, so i believe i can just splice the PCM wire on the new harness into that wire by the relay. Correct me if im wrong.
As for the red wire, i know it is the fuel pump prime connection. I cant remember where it went on the old engine and would like some help on that please.
Thanks.
Old Jul 11, 2008 | 10:32 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally Posted by BCdawg57
As for the red wire, I know it is the fuel pump prime connection. I cant remember where it went on the old engine and would like some help on that please.
Thanks.
On the early cars it went to the ALDL connector.
On '90-'92 it is just loose under the hood coming from the relay.(black plug)
It's just there if you need to run the fuel pump with the engine off.
Old Jul 11, 2008 | 08:54 PM
BCdawg57's Avatar
Cool. Thanks.
RazorN8
Jan 7, 2022 11:44 AM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
