Slow crank
Old Jul 10, 2008 | 10:29 PM
Crossbreed's Avatar
Car: '87 IROC-Z
Engine: 5.0 TPI
Slow crank
I'm having a problem with this IROC I just baught. It cranks way to slow. I've tried two different batteries, a new mini starter (the old one was fried) and I even jumped it to another vehicle and it still cranks to slow. The car hasn't started since I purchased it and I'm pretty sure at this point that it is ignition related but I need it to crank (faster) before it will ever fire.
Oh and it's an auto, 305, TPI, '87 IROC.
Old Jul 10, 2008 | 11:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Slow crank
Are all the battery and starter connections in good shape?
Does it turn at a consistenly slow pace, or does it turn and then sort of stop and hesitate for a second before starting to turn again?
Old Jul 11, 2008 | 10:20 AM
Crossbreed's Avatar
Car: '87 IROC-Z
Engine: 5.0 TPI
Re: Slow crank
It has new battery terminal and a new positive cable. All the other wiring is good. It is a cosistant crank. Just for kicks though, what would cause it to crank inconsistantly?
Old Jul 11, 2008 | 10:26 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Slow crank
whats the CCA rating on the battery? i would think you would need more cca's
Old Jul 11, 2008 | 10:30 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Slow crank
Ignition timing advanced too far.
Old Jul 11, 2008 | 10:43 AM
Crossbreed's Avatar
Car: '87 IROC-Z
Engine: 5.0 TPI
Re: Slow crank
My battery has 500 cca but I jumped it off of a car that had 750 cca. I would think that wouldn't matter. I'm probly wrong though.
I'm sure I have an ignition problem. I may be wrong about the consistant cranking. I'll have to check it later.
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
