horn problem please read
Old Jul 11, 2008 | 08:22 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
recently when i turn my wheel to the left at one dead spot whenever i pass it my horn goes off/turns on. if i keep turning it turns off and when i turn back pass that one point horn goes off/turns on.
so stupid
what part would be shorting/grounding the horn?
even does it when the horn button is off so its something deeper/internal
Old Jul 15, 2008 | 11:27 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Re: horn problem please read
It sounds like there is a wire caught up in the sterring harness under the dash,you would ahve to remove the bottom cover plate of the dash and look to see if there is a wire pinching somewhere around the wheel.
Ghettobird52
Jul 5, 2024 11:18 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
wayshegoes
Aug 17, 2015 12:00 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
