starter wiring problem
Old Jul 16, 2008 | 03:55 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
I tried to start my car yesterday but when I got in it there was no power at all to anything except for my radiator fan which is wired directly to the bat by a switch. So I got out and jiggled the wired that go to the started and after some jiggling the interior lights came on. But when I turned the key to start it the power died again (as soon as the key hits the "start" position). So I jiggle again and the power comes back again, and the power dies again when I try to start it. This goes on for a while before someone held the wires down after the power came back which allowed the car to actually start. What the heck is going on here? Obviously something is wrong with those starter wires, but what could it be? The main battery cable that goes to the starter is brand new BTW. Any help would be great.
Old Jul 17, 2008 | 05:38 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: starter wiring problem
the fusible links there at the starter are messed up.
Old Jul 17, 2008 | 11:36 PM
shingadaddy's Avatar
Car: 91 Z.
Engine: 5.7 TPI
check your battery connections too. Take 'em off and inspect/clean and reinstall tight. Some times its the simple things....
Old Jul 17, 2008 | 11:45 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
yeah id bet u have alot of corosion at the battery or the leads arent very tight its more probably the the fusable link theory...
Old Jul 18, 2008 | 05:19 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I stand by my fusible links theory., but agree that most times no power is something simple like battery terminals.
Old Jul 18, 2008 | 12:11 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
well ur theory is plausible im just saying the corosion or looseness is more likely
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
