Need Help!!! Lights not working!
Old Jul 20, 2008 | 04:18 PM
DanniBoi91's Avatar
Car: 1987 Camaro SC
Engine: 355 V8
Transmission: TH350
Axle/Gears: Stock peg leg (for now)
My headlights, tailights (im pretty sure), all interior lights and the cd player and horn dont work. But it starts up,thirdbrake light works and hazards work too. Please get back to me and let me know whats going on and what i can do to fix it.
Old Jul 20, 2008 | 06:54 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Need Help!!! Lights not working!
did you check your fuses???
maybe your headlight switch is going out, and caused a fuse to pop
seems odd, normaly your headlights will work but your parking lights/dash lights wont work in a case like yours
Old Jul 20, 2008 | 11:55 PM
DanniBoi91's Avatar
Car: 1987 Camaro SC
Engine: 355 V8
Transmission: TH350
I dont know if this makes any more of a difference of how this happened but i was driving it when it happened, i was out drifting around in the rain and then about 5 mins later i was at a red light and it just shut off, radio and lights. I have 2 12" subs and a 650 watt amp, so maybe that had something to do with it? I dont know....Let Me know.
and all interrior lights dont work either
Old Jul 21, 2008 | 06:28 AM
kcb37's Avatar
Check your fuses, check to make sure your lights are still good.
Also check your grounds.
I say check your lights because I have a 96 Silverado with a Corvette rollpan, drove thru some water one day and blew all 4 tail lights.
I also had the right headlight fill halfway up with water.
Old Jul 21, 2008 | 12:44 PM
DanniBoi91's Avatar
Car: 1987 Camaro SC
Engine: 355 V8
Transmission: TH350
No positive power is going to fuse box, and im able to bypass the fuse box and get the lights to work, but nothing with the radio.
Old Jul 21, 2008 | 08:00 PM
89RS_82Z's Avatar
then you need to get out a wire daigram and find out where the power lead is going to the fuse box...... i will check mine out if i remember to LOL
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
