AC / Heater Control Unit Burning Up
Old Jul 20, 2008 | 07:20 PM
Blaze of Glory's Avatar
Car: 92 Firebird
Engine: 3.1L V6
My AC/Heater fan speed was stuck on one setting. I eventually found out that the fan speed switch was burned up. You can see pictures of the offending switch here. https://www.thirdgen.org/forums/tech...tml?highlight=
I pulled a unit from a Junk Yard and replaced the switch. Everything worked after that (actually my AC isn't cold and the compressor cycles on and off every few seconds, but I don't think that's related). But I guess I never found out WHY the switch burned up in the first place.
I usually have the control unit set to the AC settings or the Vent setting. Well the other day the weather was just right and I turned off the unit. After a few minutes I started to smell something burning. After a few more minutes I saw smoke coming from the control unit. I turned the lever back to the vent setting and the smoke subsided. I turned the unit back off and I started to see smoke again.
Any ideas why this is happening?
Old Jul 21, 2008 | 10:47 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
SWITCH THE SWITCH
Because you replaced a used one for
a used one you didn’t gain anything.
Also, even in the “OFF” position
there is current flowing thru the switch
to maintain a very slow blower speed.
Before you install a new switch do a
routine check for shorts in the blower circuit.
Happy Racing!
-If people drove any slower
they’d be going backwards-
Old Jul 21, 2008 | 01:42 PM
Car: 92 Firebird
Engine: 3.1L V6
Re: AC / Heater Control Unit Burning Up
I just thought it was interesting how the issue only arises when the unit is set to off. I'll dig up the schematic and inspect.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
my86bird
Oct 23, 2015 12:20 PM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
