how to check fuel pump voltage?
Car: 1986 IROC-Z28
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: how to check fuel pump voltage?
Engine: TPI
If you stick your testlight on the tan/white wire (with the relay in), you should see it light up briefly (for 2 seconds) when you turn the key on.
Then when the car starts, the light should come on again and stay on. Does it?
Lou
Lou
92camaroJoe
Aug 13, 2015 06:07 AM
