Autometer oil pressure gauge wiring help
Old Aug 10, 2008 | 08:38 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Im tring to wire in an autometer oil pressure gauge. I cant use the autometer supplied sender because I have no oil port to put it into on my block. The blocj is a 75 350. I have the factory oil pressure switch at the rear of the block up under the distributor. The oil port by the oil filter is plugged and cant be used. On the factory pressure switch there are 3 wires, orange, tan, and tan/white. I know orange goes to the fuel pump. I believe tan is to the guage. However when I splice the autometer guage onto that wire both guages just peg all the way to the highest reading. What am I doing wrong? Is there a better way to wire this?
Matt
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
